Date/Time: Mon, 20 May 2024 03:53:13 +0000
CQG FIX connection problem
View Count: 1365
[2015-06-01 08:43:52] |
Blue Brazilian - Posts: 42 |
My connection was working OK on Friday but now fails with a Windows 10060 error: CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-06-01 10:40:36 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-06-01 10:40:36 socket (15) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-06-01 10:40:58 socket (15) | Shutdown and closed. | 2015-06-01 10:40:58 CQG FIX Trading FIX: Socket connection was closed without any logout messages sent or received. | 2015-06-01 10:40:58 CQG FIX Trading FIX: Disconnected. | 2015-06-01 10:40:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-06-01 10:40:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-06-01 10:40:58 CQG FIX Trading FIX: DisconnectFIX called. | 2015-06-01 10:40:58 CQG FIX Trading | Disconnected. | 2015-06-01 10:40:58 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-06-01 10:40:58 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-06-01 10:41:03 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-06-01 10:41:03 socket (16) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-06-01 10:41:24 socket (16) | Shutdown and closed. | 2015-06-01 10:41:24 CQG FIX Trading FIX: Socket connection was closed without any logout messages sent or received. | 2015-06-01 10:41:24 CQG FIX Trading FIX: Disconnected. | 2015-06-01 10:41:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-06-01 10:41:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-06-01 10:41:24 CQG FIX Trading FIX: DisconnectFIX called. | 2015-06-01 10:41:24 CQG FIX Trading | Disconnected. | 2015-06-01 10:41:24 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-06-01 10:41:24 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-06-01 10:41:29 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-06-01 10:41:29 socket (17) | Error received in OnConnect while connecting. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2015-06-01 10:41:50 socket (17) | Shutdown and closed. | 2015-06-01 10:41:50 CQG FIX Trading FIX: Socket connection was closed without any logout messages sent or received. | 2015-06-01 10:41:50 CQG FIX Trading FIX: Disconnected. | 2015-06-01 10:41:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-06-01 10:41:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-06-01 10:41:50 CQG FIX Trading FIX: DisconnectFIX called. | 2015-06-01 10:41:50 CQG FIX Trading | Disconnected. | 2015-06-01 10:41:50 Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-06-01 10:41:50 CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-06-01 10:41:55 socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-06-01 10:41:55 |
[2015-06-01 09:36:14] |
At this time we can connect to the same CQG server: CQG FIX Trading FIX: Connecting to fixapi.cqgtrader.com. Port: 6912. | 2015-06-01 04:47:49
socket (0) | Resolved address fixapi.cqgtrader.com to IP 208.48.16.214 | 2015-06-01 04:47:49 socket (3) | Connected. | 2015-06-01 04:47:49 CQG FIX Trading FIX: Sending the Logon message. | 2015-06-01 04:47:50 What this means is there is some connectivity problem from your side to the server. Refer to help topic 1.2 here about this: Http://www.sierrachart.com/index.php?page=doc/helpdetails1.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
