Date/Time: Sun, 19 May 2024 20:36:40 +0000
How do I remove the confirmation box when entering a trade and closing a trade?
View Count: 1832
[2015-05-29 17:30:59] |
User714974 - Posts: 10 |
Hi How do I remove the confirmation box when entering a trade and closing a trade? Let me know please. Thanks |
[2015-05-29 20:13:46] |
Go to the menu either for the chart or Trade DOM and select Trade >> Open Trade Window for Chart to display the Trade Window if it is not already visible. On the Trade Window press the M button. And select Confirmations. You can enable and disable all of the confirmations on that submenu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-29 20:14:15
