Date/Time: Thu, 11 Dec 2025 06:29:22 +0000
AMP and TD
View Count: 1026
| [2015-05-26 20:53:36] |
| Netz - Posts: 19 |
Hello. I am using Sierra Chart package 3 provided by AMP. How do I add TD Ameritrade or Sierra Chart U.S. Equities data to it. Data settings currently says it's not enabled with package. Thanks for the information. |
| [2015-05-26 21:16:46] |
You will need to have a direct Sierra Chart account: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
