Date/Time: Thu, 23 May 2024 16:53:06 +0000
Time Grid
View Count: 834
[2015-05-26 17:49:53] |
SgtJ - Posts: 154 |
This has been going on for a while. Can you tell me if its something I'm doing incorrectly? If I look at a 1 tic chart with the time grid lines (F5, adv setting 2) set to 10 seconds, the 1st period of the day is longer then 10 seconds, thus throwing off the 10 sec/minute scale when referencing another chart visually. How do I get the first line to appear at the 10 second mark? In the case of the attchment its at the 16 second mark. ty
time grid sc.png / V - Attached On 2015-05-26 17:48:57 UTC - Size: 67 KB - 321 views |
[2015-05-28 03:30:59] |
This will be reviewed when we can.
[2015-06-15 21:23:55] |
Jeffrey - Posts: 2105 |
This should be fixed in the next release. Your existing settings should be fine.
