Date/Time: Sat, 18 May 2024 06:22:35 +0000
[Locked] - Time on charts is off
View Count: 980
[2015-05-26 13:25:43] |
User699694 - Posts: 49 |
Hi I am trying the sierra platform out I have the ESM15 loaded but teh most current price action is not reflected, please advise? I thought it was real time data? Thanks |
[2015-05-26 13:32:24] |
For information about real-time futures data, refer to this section here: http://www.sierrachart.com/index.php?page=doc/data.php#FuturesData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-26 16:56:38] |
Thanks I now have real time data and teh price is correct However the time on all charts is off eg it says 16.55 its actually 12.55 How do I fix Thanks |
[2015-05-26 19:04:58] |
Hi I figured this out thanks
[2015-05-26 19:13:37] |
For future reference, you need to change the global Time Zone: https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-14 16:27:34] |
Hi I have a 1min chart of the TICK.Z, for some reason the time is off its starts at 1pm when the actual time is 9.30am I have the smae chart settings on my other charts and the time on these is fine Suggestions? Thanks |
[2015-09-14 17:21:58] |
Check the Time Zone setting for the chart. Make sure to set it to Use Global Time Zone: https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html#DifferentTimeZoneForCharts Also check the Session Times: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#h7.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-14 17:34:05] |
I have this all set correctly
[2015-09-14 17:44:23] |
What is the Time Zone in Sierra Chart set to? What do you have the Session Times in the chart set to? There is little other possibility unless there is incorrect timestamp data from IQ Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-14 18:32:20] |
session start time 9.30 am end 1600 Use globlal time zone is set How do I address the time issue with IQ |
[2015-09-14 18:47:32] |
What is the Time Zone in Sierra Chart set to? For more information about that, refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html With those Session Times it must be set to New York. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-14 18:57:10] |
thanks this fixed it
[2015-09-25 14:30:58] |
Hi I have a set of indicators/studies that I apply to each chart Instead of adding each separately is there a way I can save the group and add them at one time? Thanks |
[2015-09-25 18:02:18] |
Use the Study Collections feature: https://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html There is also the Chart Linking option for Studies. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ChartLinking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-25 18:03:28
[2015-09-27 17:38:44] |
Thanks Is there a way I can click on the chart itself to see what indciator is attached to that object? For example I have an arrow head, and I want to confirm what indicator that is coming from without opening the studies and going through them all? Thanks in advance |
[2015-09-27 18:10:30] |
We are not understanding this. Obviously you can see all of the studies on the chart and by default at the top of each Chart Region is the descriptive name of each study. There is no other capability beyond this.
[2015-09-29 01:23:45] |
Thanks How do I add a study collection to a chart? Thanks |
[2015-09-29 03:18:22] |
Study Collections are documented here: http://www.sierrachart.com/index.php?page=doc/doc_StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-29 14:02:22] |
Thanks Using the 'hand' tool I am not bale to move the chart to the left only up down and to the right, such that the price action is always at teh extreme right How do I fix that? Thanks |
[2015-09-29 17:27:31] |
You will need to make sure the right side fill space is unlocked: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-09 19:01:03] |
Hi I am trying back test an indicator, how do I do that? I am used to defining the stop and targets and then with that apply the indicator to a chart to see the results Thanks |
[2015-10-09 19:29:06] |
This requires creating an automated trading system. For more information, refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_AutoTradeManagment.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
