Date/Time: Sun, 19 May 2024 12:02:19 +0000
Color Bar based on Alert
View Count: 802
[2015-05-22 13:21:55] |
User14209 - Posts: 6 |
Good Morning, Not sure if this is indicated in your documentation. I wrote an alert condition in the alert tab of the study "Color Bar based on Alert", then I used "Save these settings as the default" in order to use the study in an other chart. When I use the study in another chart, the Alert Condition formula is truncated. Seems lime the "Save these settings as the default" condition saves only the first 130 characters of the Alert Condition. Regards Robert |
[2015-05-23 03:41:29] |
What you describe very well could be the case. We will see how to overcome this limitation. It may be a while though before we can get to this.
