Date/Time: Sat, 07 Mar 2026 14:46:28 +0000
Tick data
View Count: 1145
| [2015-05-22 00:16:01] |
| Kinobe - Posts: 86 |
I am in trial period and I am a bit confused : 1- does the trial mode offer tick by tick data replay via SC historical data? if not, what should I do?. |
| [2015-05-22 04:59:00] |
Yes it does. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-22 20:53:13] |
I followed these instructions already, but with SC historical data is selected,I replayed US stock and charts move with 1 min candle and not tick. So I don t know what I am doing wrong for not getting tick replay with SC Historical Data? help me please futhermore, it is indicated on your linked page : [...Therefore, with these particular services the historical data will not be tick by tick unless you use the Sierra Chart Exchange Data Feed.] that is the reason why I am confused. By reading this, I understand that SC Historical Data do not provide tick by tick but I need to sucribe SC Echange Data in order to get tick by tick data... |
| [2015-05-22 20:57:26] |
As the documentation indicates here: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html#Included Tick by tick data is only provided for popular futures markets. Not stocks. For stocks you would need to use the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-22 21:15:56] |
ok so in order to get US stock data replay tick by tick, I need : 1 - Sierra Chart Package Needed: 1 for 20 USD/month 2 - Sierra Chart Real-Time and Historical Exchange Data Feed - 35$ USD/month 3 - U.S. Equities (NYSE, NASDAQ, AMEX, OTCBB): Price 10.5 USD/month for a total of 65.5$ USD/month correct? |
| [2015-05-22 21:32:34] |
Yes. However: 3. You can skip this if you just need historical data. You can also use the BATS exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
