Date/Time: Sun, 19 May 2024 18:16:33 +0000
TPO Chart's Draw Peaks & Valleys until future intersection does NOT end at future intersecti
View Count: 1063
[2015-05-21 20:04:02] |
rex2nd - Posts: 12 |
On TPO chart, there is setting draw peaks valleys, when select extend peaks & valleys using until future intersection funtion, it does NOT end at future intersection initially, but only after restart SC , it will work properly. why is this happen? thanks Rex. |
[2015-05-21 21:38:52] |
Could you provide us a Chartbook containing one chart and the TPO Profile Chart study which demonstrates this problem. Here are instructions to attach the file: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-22 06:58:42] |
here is the file
tpo_testing_future intersection end.cht - Attached On 2015-05-22 06:57:38 UTC - Size: 47.82 KB - 318 views |
[2015-05-25 05:36:33] |
any update on this issue? thanks Rex |
[2015-05-27 00:24:55] |
User567294 - Posts: 47 |
this was happen when you merge with next profile, then the line wouldn't update.any solution for this? thanks |
[2015-05-28 10:12:33] |
We will check on this.
[2015-05-29 13:21:52] |
We do see the problem. And we are working to solve it. It will be solved by the end of the day today.
