Date/Time: Sat, 27 Apr 2024 08:00:25 +0000
Watermark
View Count: 3659
[2015-05-20 21:45:33] |
User40278 - Posts: 3 |
Dear support-team, is there any possibility to add watermark text to the charts for better identification on more/bigger screens ? If not, is it on your task list ? Thanks in advance, Alex |
[2015-06-02 10:34:36] |
Nobody from the support willing to answer my question ?
[2015-08-04 12:20:55] |
Japhro - Posts: 120 |
I agree that this is a needed feature
[2016-01-19 12:18:33] |
bwalks123 - Posts: 122 |
Yes, please add the watermark capability.
[2016-01-19 18:04:47] |
There are no plans to support this. We could add a study though that displays the current symbol of the chart using a controllable font size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-27 14:48:11] |
That would be a very useful addition Sierra, if you have 8 identical charts open with different symbols it gets a bit confusing which is which with only a tiny title on top to go by. Font size, font colour, opacity would be a great addition
[2016-03-27 21:52:25] |
We added a "Symbol Display" study that you can use.
[2016-03-28 09:07:06] |
Trader Ra - Posts: 87 |
great addition however some of the settings dont work as expected. vertical and horizontal position values dont seem to work. be good to also have the ability to choose what text to display instead of just the symbol. the short name setting (under subgraphs) doesnt seem to work either.
[2016-03-28 10:16:07] |
Those controls set the initial position and then you can move the symbol by left clicking on it when a non-drawing tool is active. Move the Pointer to move it to a new location and then left click again. The Short Name setting will not alter the text. Only the symbol can be displayed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-16 18:11:29] |
tommartin321 - Posts: 74 |
It would be very helpful if there was a way to lock the display on the screen. So it would act like a true watermark. Therefore, when I'm clicking around on the screen I'm not accidentally clicking on the symbol text box. Thank you. |
[2020-01-16 19:00:34] |
zippyzip - Posts: 293 |
yes to perminent with option to transparent the text to fade into back
[2020-01-16 22:05:20] |
The Windows operating system does not support transparency with text. We will see if we can add a lock option to the Symbol Display study. Update: A Lock Position Input has been added to the Symbol Display study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-17 08:56:20
[2022-07-22 17:00:25] |
j4ytr4der_ - Posts: 918 |
Is there any way to change the font used to display the symbol with this study? I can't seem to find it if so.
[2022-07-25 14:48:53] |
Sierra_Chart Engineering - Posts: 14107 |
Modify the study. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
