Date/Time: Fri, 13 Nov 2026 22:08:52 +0000
disable order confirmations
View Count: 9124
| [2015-05-19 13:17:53] |
| User193151 - Posts: 10 |
trying to disable popup for order conf but i can't find the following per the instructions: "To disable confirmations press the Menu (M) button on the Trade Window and disable the confirmation options that you do not want." i can't see this option in sierra - please provide instruction and screenshots to show me where to disable trade conf popups. |
| [2015-05-19 13:26:05] |
| SgtJ - Posts: 154 |
Trade, open trade window for chart, click on "M", confirmations.
| [2015-05-19 13:29:29] |
got it - thx
| [2015-05-19 18:37:03] |
This is done through the Trade Window. Here is the documentation: Basic Trading and the Trade Window: Main/C >> Menu (M) button Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-11-03 21:42:46] |
| User519569 - Posts: 18 |
This is a common and frustrating problem, so I hope this helps a lot of people. I wish I could a paste picture here to show you what the "Trade Window" is, but I can't. So here's a description: the "Trade Window" is a vertical rectangular box that usually comes attached to the left side of a DOM. This "Trade Window" has all the buy and sell buttons, plus the flatten button and the immensely wonderful Break-Even button, the single most important feature that convinced me to switch to Sierra Charts and EdgeClear brokers. Just to the right of the orange and brown "CancelALL" button is a tiny gray box with the letter "M" on it. Click on this and the menu comes up that includes "Confirmations." Make sure each of these does NOT have a checkmark beside it (by click-toggling). Note that your order confirmations may not immediately stop. Just be patient. It seems to take a while for the system to get your message and stop sending order confirmations. Hope this helps. That cute little "M" button sits right in the middle of everyone's blind spot, as if it were camouflaged by space aliens with a sense of humor. :) Maybe it should be colored red or something. Cheers.
Date Time Of Last Edit: 2022-11-03 21:44:54
