Date/Time: Thu, 09 May 2024 21:01:00 +0000
The new Breakeven Button...
View Count: 2102
[2015-05-19 09:49:58] |
User51760 - Posts: 108 |
...is brilliant. Thank you so much. Is ist possible to add it to Menu > Global Settings > Customize Keyboard Shortcuts? Best, Chris |
[2015-05-19 09:59:40] |
Yes we can do this.
[2015-05-19 12:07:53] |
Futurestrader77 - Posts: 126 |
@User51760 Chris, from which button are you talking about? Thanks! |
[2015-05-19 12:48:23] |
Futurestrader77, since Version 1255 there is a Move To Breakeven Button added to the Trade Window. As an illustration please refer to the attached picture. Best, Chris |
move_to_breakeven_button.png / V - Attached On 2015-05-19 12:46:59 UTC - Size: 48.4 KB - 474 views |
[2015-05-19 12:55:26] |
User11942 - Posts: 298 |
Hmm, interesting... I don't have it in compact mode, but only in main trade window.
[2015-05-19 13:01:42] |
Update. I downloaded 1256 and now I have the button in compact mode as well. Thank you SC team for adding it to compact mode! It's really useful.
Date Time Of Last Edit: 2015-05-19 13:12:36
[2015-05-19 13:29:44] |
Thank you Chris! I couldnĀ“t find it because I still have 1254.
[2015-05-26 19:13:45] |
Al SC Developer - Posts: 434 |
The ability to define a shortcut for the move to break even function will be in next release. It is in the Trading Keyboard Shortcuts section.
[2015-05-27 23:34:19] |
User46930 - Posts: 28 |
is there way to set that b/e offset? cos I got b/e offset set to +1 on targets tab so b/e button could respect this value?
[2015-05-28 02:29:36] |
In response to post #9 and #10 this is controlled through the Set tab of the Trade Window. It is named "Move to BE Offset".
[2016-07-05 04:41:47] |
Acro - Posts: 436 |
Is there anyway to add BE to the chart trade menu in the same way that eg "Flatten and Cancel" can be done by a right click ? That would be incredibly useful as it would speed up the time to get a BE in if you did not have the Trade Window visible at that time. I looked in the list of commands you can add to the chart trade menu but I could not see "BE". |
