Date/Time: Thu, 23 May 2024 16:52:51 +0000
data
View Count: 757
[2015-05-18 13:55:53] |
julian pineda - Posts: 60 |
I am having data issues, the information does not appear and when i do "delete and download" always download the last bar, but the previous ones disappear. it shows me like the day starts 1 minute ago the delete and download process, its no loading the past data. what steps do you recommend to fix this? |
[2015-05-18 16:26:45] |
This is now solved. Right-click before the missing bars in the chart and select Delete Data and Download.
