Date/Time: Sat, 18 May 2024 04:37:52 +0000
How to save a spreadsheet to open in other app.
View Count: 980
[2015-05-16 22:34:28] |
User911705 - Posts: 89 |
I'm guessing there should be a way to save SC spreadsheets in something like a .xls, .cvs or .txt format, but I can't figure out how to do so.
[2015-05-16 23:20:51] |
Select File >> Save As. At the bottom of the Save File window set the file type to Text Files.
[2015-05-16 23:39:34] |
That's what I tried to do, but all that happens is that it reverts to save as .scss file. I'm a pretty technically astute person and I can't see that I'm doing anything obviously wrong. Thanks for your help. |
[2015-05-16 23:47:05] |
OK we see. Something must have recently gone wrong with this. We will fix this.
[2015-05-16 23:53:44] |
Thank you so very much!
