Date/Time: Thu, 02 May 2024 15:02:06 +0000
How to find Zen Fire futures symbols??
View Count: 2322
[2013-03-26 19:05:44] |
Harvey W Hampton - Posts: 6 |
I have a futures account at Mirus Futures, and I use the Zenfire data/trading feed. I am a new user to Sierra Charts. Sierra Charts will start and run well. I can easily make a connection to Zen Fire, but I cannot locate the futures symbols. The futures symbols used with Ninja Trader will not work with Sierra Charts. |
[2013-03-26 19:21:40] |
You will find the symbols listed in File >> Find Symbol. If you do not see them listed, then goto Global Settings >> Symbol Settings and press the Update From Server button. Press OK. If there is a particular symbol you do not see listed, then let us know what it is and we will add it for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-03-26 19:22:09
[2013-03-26 19:54:36] |
We apologize, we realize we have not yet set up the symbols for Zen Fire. Just give us a few minutes to do this now.
[2013-03-30 22:48:10] |
Let us know if you have any further issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
