Date/Time: Sun, 28 Apr 2024 07:48:00 +0000
Threads from the old support board ...
View Count: 2685
[2013-03-20 08:10:23] |
tobi - Posts: 351 |
will they be moved to the new board?
[2013-03-21 00:58:51] |
This is not easily accomplished. It may be done later on.
[2013-03-21 13:04:45] |
Sawtooth - Posts: 3980 |
There is a wealth of information in the old support board. If you don't migrate it, please maintain a link to it.
[2013-03-21 15:26:47] |
Sierra Chart - Max - Posts: 5597 |
We will not be removing the old board any time soon.
Sierra Chart Support |
[2013-03-21 17:07:11] |
blueberrycake - Posts: 3 |
Also, please add Search functionality to the new board, if possible.
[2013-03-21 17:19:07] |
Search capability is coming.
[2013-03-21 17:29:46] |
I have Edit and Delete links on all posts except mine. Will we be able to edit our own posts?
[2013-03-21 17:35:03] |
We will check into this.
[2013-03-21 17:37:08] |
@tomgilb This is resolved.
Sierra Chart Support Date Time Of Last Edit: 2013-03-21 19:02:19
[2013-03-21 17:59:03] |
Why is my user name shown in the previous post instead of my public name?
[2013-03-21 19:02:49] |
I copied the wrong name.
[2013-03-21 20:47:23] |
I have the Edit link now, but it says Only Moderators can edit posts.
[2013-03-22 09:38:58] |
tobi - Posts: 351 |
Will "Preview" of a message also be added? This was a helpful function in the old board.
