Date/Time: Wed, 15 May 2024 19:39:39 +0000
Price scale can't be adjusted after switching from linear to logarithmic
View Count: 863
[2015-05-06 19:25:54] |
User534053 - Posts: 25 |
Hi, When I switch the chart from linear to logarithmic, I can no longer use the mouse to drag up and down on the price axis to show a smaller or larger price range. Is this a bug? Thanks, Markus |
[2015-05-06 20:26:21] |
This is by design.
[2015-05-06 21:21:19] |
Ok, thank you for the quick response. Why is it designed that way? Because it would be too time-consuming on the engineering side to add that functionality?
[2015-05-06 23:45:13] |
The problem is it does not always function properly with a logarithmic scale and can work very abnormally.
