Date/Time: Mon, 08 Jun 2026 09:01:13 +0000
Command to include columns with no data?
View Count: 2421
[2013-06-03 19:47:44]
George Slezak - Posts: 40
My charts have lost their previous check in chart settings, to include columns with no data. Is there a global command to reinstate this checked box?
[2013-06-03 21:17:00]
This is found in Chart >> Chart Settings >> Advanced Settings.
[2013-06-04 08:10:03]
The checkbox simply has been moved to the 2nd tab of the Chart Settings window. This is all. Nothing else has changed.
[2013-06-04 16:29:51]
Sierra Chart - Max - Posts: 5938
Thank you for the reply.
You said The checkbox simply has been moved to the 2nd tab of the Chart Settings window. This is all. Nothing else has changed.
But my question is asking if there is a way that the default for all charts is to have that box checked. Every time I open a new chart I have to go to chart settings and check that box. When I go to chart settings, SOME BOXES ARE ALREADY CHECKED as the default setting. IS THERE SOME WAY TO HAVE THE "include columns with no data" box checked as part of the default opening of a chart?
Is there a way for all existing charts to have a default check in that box applied?
george
Sierra Chart Support
[2013-06-04 22:10:25]
The answer to this is to duplicate an existing chart with that option checked. Please see:
https://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#DuplicateChart
Date Time Of Last Edit: 2013-06-04 22:11:21
