Date/Time: Tue, 14 May 2024 12:44:05 +0000
GEZ6 chart data not updating...and missing yesterdays data
View Count: 883
[2015-05-05 15:07:19] |
User71961 - Posts: 144 |
i just duplicated my continuous 90 day chart for /ESM5 (then changed the ticker to /GEZ6) The MessageLog indicates that SC downloaded the data The /GEZ6 chart (CME dec 2016 eurodollar future) does not update, and seems to be missing some days data also. What am i doing wrong? I'm using TD Ameritrade as my data source. I'm using SC version 1224 |
[2015-05-05 16:31:47] |
This is now resolved. It should now be updating and the missing data filled in. If you ever see a problem like this again select File >> Disconnect and File >> Connect to Data Feed to switch to the other server.
