Date/Time: Mon, 13 May 2024 23:01:45 +0000
ChartTrade fill labels mask price action
View Count: 919
[2015-05-04 19:49:51] |
VPhantom - Posts: 18 |
Hi! I've browsed through the Chart Trading settings quite a few times and came up empty: is there any setting which is causing this very close placement of execution labels on my charts? (See attachment.) I like that labels for sales are above, buys are below, but they're not far enough to clear the price bars and sometimes (like this example) important areas are covered. I wouldn't want to reduce markers to just tiny triangles (easy to miss, less detailed in my screenshot archives) but I'm stuck. |
sc_orders_hide_price.png / V - Attached On 2015-05-04 19:45:55 UTC - Size: 1.52 KB - 323 views |
[2015-05-04 21:57:40] |
The only thing you can do is reduce the text size for them and the amount of information displayed by those order fill labels.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-04 21:57:54
