Date/Time: Mon, 13 May 2024 23:25:55 +0000
Supporting QUODD data
View Count: 1220
[2015-05-04 07:25:16] |
User659520 - Posts: 6 |
I am a MyTrack data feed user. Their service has been replaced by QUODD, if I am not mistaken. Do you or will you intend to support QUODD? Thanks, Ronen |
[2015-05-04 08:28:52] |
No, definitely we would not be adding support for another data feed. We recommend using the Sierra Chart Real-time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-04 08:39:35] |
I tried SC Historical feed but I saw that it is limited to 1000 tickers per day. I need about 3000 EOD data every day.
[2015-05-04 09:03:42] |
This data feed is not the Sierra Chart Historical Data Service: Sierra Chart Exchange Data Feed It also provides real-time data and has no limitation on the amount of historical daily data that can be downloaded. It should meet your requirements. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-04 09:04:17
[2015-05-04 09:26:38] |
If I understand correctly I need to pay 45.5 $ per month for us equities. What is the service level that is required?
[2015-05-04 09:33:44] |
Yes. This is correct in regards to the price. The Sierra Chart Real-time Exchange Data Feed can be used with any Sierra Chart service package. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
