Date/Time: Tue, 14 May 2024 17:51:31 +0000
e-mini historical data
View Count: 951
[2015-05-04 00:04:54] |
User78439 - Posts: 21 |
I am using package 3 for SPY historical data for back testing. However, we have the maximum data until 19h55 each day. I am wondering if it is possible to have 5m chart of e-mini historical data. If yes, it is same symbol as that frequently used ? If not, there is a way to have this historical data for back testing ?
[2015-05-04 00:38:31] |
Yes. The futures symbol begins with ES and can be found in File >> Find Symbol.
[2015-05-04 01:27:52] |
Thanks, I got it. But when comparing ES chart with that of SPY(I choose NY time in my chart setting), it seems that ES future in chart is Chicago time ?
Date Time Of Last Edit: 2015-05-04 01:28:52
[2015-05-04 02:52:32] |
It depends upon what the time zone setting is. Refer to this page: http://www.sierrachart.com/index.php?page=doc/doc_TimeZone.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-04 12:45:16] |
User742670 - Posts: 43 |
Hello, Thanks a lot for the info..the first mentioned solution solved it for me..I would have another question regarding historical data. When I chose FDAX historical data graph to be loaded it automatically set the period back 4380 days but the historical data are only till October last Year...How can i download more then that? Many thanks David |
[2015-05-04 16:59:26] |
Follow the instructions here to create a Continuous Futures Contract chart: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
