Date/Time: Wed, 15 May 2024 15:06:47 +0000
Sometimes wrong colors for candle stick outlines
View Count: 1354
[2015-04-30 06:30:21] |
nicktrader - Posts: 665 |
After download the current version 1251(before 1241) sometimes I get wrong colors for the outlines
Candle Colors.png / V - Attached On 2015-04-30 06:23:29 UTC - Size: 29.09 KB - 354 views |
[2015-04-30 16:56:09] |
Check the color settings and Candlestick bar related options as documented here: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-02 06:55:17] |
I didn't change anything in the graphics setting and how (or where) is it possible that some candles are with different colors and lot of others are correct. I can't imagine that there is a way for a setup like this.
[2015-05-04 09:00:20] |
You need to enable this option in Global Settings >> Graphics Settings: Color Candlestick High-Low Using the Outline Colors Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-04 10:02:04] |
First question: How to set enable? As you can see in the attached file the color for "CandleStick Up Outline" is set on "green" but some of up/ bullish candles in the chart have a red outline. The outlines are not permanent red or green. I am astonished about the fact that the colors of the outlines are only sometimes wrong. |
Candle Colors example II.png / V - Attached On 2015-05-04 09:50:13 UTC - Size: 55.76 KB - 329 views |
[2015-05-04 10:08:56] |
This option is on the "Other" tab of the Graphics Settings window.
