Date/Time: Tue, 21 Apr 2026 01:46:05 +0000
CCI Settings
View Count: 3760
| [2013-03-26 18:51:19] |
| User23815 - Posts: 217 |
I'm a new user. On the CCI study settings the Multiplier is preset at 0.015. I was using Ninja and then Ensign. I haven't used a multiplier before. Is that a standard setting or will I need to change it in order to get similar settings? Also, there is a Line2 and Line3 Value available. How can I add additional lines? Thanks
| [2013-03-26 23:24:11] |
This is the standard Multiplier setting for the Commodity Channel Index. It should be left as is. You can add additional lines by using the Horizontal Line study. Follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#AddingHorizontalLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
