Date/Time: Fri, 03 May 2024 10:01:45 +0000
Regarding Historical SC data
View Count: 1387
[2013-06-03 05:07:19] |
milo2020 - Posts: 7 |
It appears to me that the most recent daily bars begin at midnight and end at 11:59:59PM. Is there a way to restrict this data? For example, for Crude Oil futures I'd like the daily data from 9:00AM open to the 2:30PM close.
[2013-06-03 05:16:34] |
Your first statement is incorrect. The data is from the exchange and they set the session times and it cannot be changed. It is 24 hour data. Refer to this help topic for an alternative: http://www.sierrachart.com/index.php?l=doc/helpdetails13.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
