Date/Time: Sun, 22 Nov 2026 20:42:50 +0000
Symbol unknown
View Count: 1919
[2015-04-25 14:25:39]
User39772 - Posts: 311
I connected SC to IB. If I want to load a stock Symbol of ASX (all enabled in IB and visible in IB charts)
via Find Symbol I only get the message "Symbol unknown". The stock symbol is ANZ, same happens with other symbols.
I also wonder why unter Find Symbol I do not see a pull down menue for stocks, for all other itema like forex
futures, cfd there are submenues available that list all possible underlyings.
[2015-04-25 21:27:08]
Sierra Chart - Max - Posts: 5986
For the proper format for IB Stock symbols please refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock
It is not practical to list all Stocks, as there is just too large of a number of them, and there is no list of most popular or traded stocks.
Sierra Chart Support
Date Time Of Last Edit: 2015-04-26 00:00:40
[2015-04-26 09:42:57]
try "ANZ-STK-ASX" or "ANZ-STK-SMART/ASX"
I see "waiting for download" and the correct company name in the chart window but no chart becomes vssible.
Other symbols from US Exchanges like AAPL etc. work fine i SC.
If I open a chart for ANZ in TWS everything is fine.
[2015-04-27 00:51:08]
You may also have to specify the Currency Code. For example: ANZ-STK-ASX-AUD
