Date/Time: Sun, 19 May 2024 01:39:31 +0000
SC 1248 and 6J historical data
View Count: 897
[2015-04-20 01:20:55] |
umair1 - Posts: 86 |
I'm using SC 1248 with rithmic. My broker is Deep Discount Trading/Crossland/Wedbush. I opened a historical chart for 6JM5-CME. I opened the continuous futures contract, volume based rollover, back-adjusted. I set the Days to Load to 2000. The data in mid December 2014 is off. See attached images. The first image shows the chart zoomed out. The second image shows the chart scaled to appropriate values (roughly the high and low that the contract has recently traded). If I downgrade back to 1241 then I don't have this problem. So I'm using that for now. But I thought I'd let you guys know. |
6j-zoom.png / V - Attached On 2015-04-20 01:18:40 UTC - Size: 72.39 KB - 287 views |
[2015-04-20 02:07:36] |
We are aware this can happen due to some changes related to this in the newer versions. You just need to re-download the data as explained here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-20 02:08:37
