Date/Time: Mon, 13 May 2024 02:30:49 +0000
VbP -Dom wrong VPOC.
View Count: 890
[2015-04-19 23:06:06] |
vectorTrader - Posts: 86 |
VbP is not shifting the VPOC. Something has changed in v1241 where VPOC does not shift until there is a significant difference between the old and the new VPOC. I have this problem not just on the DOM but also on other charts. Please advise. |
2015-04-19 19_01_19-SC ESM5-CME [CB] #6 L_2 E-Mini SP 500.png / V - Attached On 2015-04-19 23:05:23 UTC - Size: 56.42 KB - 320 views |
[2015-04-19 23:24:34] |
Update to the latest prerelease with Help >> Download Prerelease. That should solve the problem. Also with the problem like this, we will only accept an image from a chart. Trying to understand this on a Trading DOM is very difficult. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
