Date/Time: Sat, 11 May 2024 21:12:57 +0000
Volume Profile?
View Count: 807
[2015-04-18 21:57:01] |
User25633 - Posts: 10 |
I have a large continuous volume profile on my chart and if I set it to align on the left I have to scroll to the far left to see it. If I set to up to align on the right I have to scroll to the far right to see it. How do I set up the volume profile so I can always see it regardless where I am at on the chart? Thanks.
[2015-04-18 22:10:25] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#RightAligning Also there is this Volume by Price study input you can set to Yes: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#AlwaysDisplayLastProfileWithinView Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-18 23:59:09] |
i960 - Posts: 360 |
What does Align to Far Right actually do? I've never seen this change anything in how a VbP is displayed; only "always display last profile within view" matters. If I go to a right-aligned VbP right now and turn on/off "align to far right" it makes no difference in how the VbP is displayed. |
