Date/Time: Mon, 13 May 2024 04:59:07 +0000
Bar Counter Study
View Count: 1127
[2015-04-17 18:26:18] |
User83814 - Posts: 26 |
I was not able to find the bar counter study referenced here: https://www.sierrachart.com/supportboard/showthread.php?t=23670 Is it still available? Thank you |
[2015-04-17 18:28:00] |
Please give us the name of the particular study you are looking for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-17 18:40:55] |
I'm quoting your reply in that thread: Or maybe you are interested in the new Bar Counter study. Please update to the latest version and you'll find it in the list of available studies.
it's post #3 in this thread: https://www.sierrachart.com/supportboard/showthread.php?t=23670 |
[2015-04-17 18:45:29] |
OK the actual name of the study is "Bar Numbering".
[2015-04-17 18:48:25] |
ok thanks it seems it's missing from the Technical Studies Reference documentation page that's why i was not able to find it a moment ago can i specify how often to reset the counter or numbering (for example every 5 minutes)? Date Time Of Last Edit: 2015-04-17 18:50:47
[2015-04-17 23:27:36] |
This will be documented. There is the Number Every N Bars input that may accomplish what you want. But we are not certain what the timeframe of the chart bars you are using.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-17 23:27:49
