Date/Time: Sun, 19 May 2024 12:02:29 +0000
Move stop to breakeven - first target on two target order.
View Count: 2448
[2015-04-17 16:30:07] |
User65754 - Posts: 25 |
I need help with a simple order configuration: Qty 2 First target 5 ticks Second target 10 ticks Initial stop for both set at 7 ticks When the first target of 5 ticks is reached and the remaining qty goes to one, I want the stop to move to order entry point minus 5 ticks (i.e. worst case zero profit/loss once the first target has been reached). Step by step instructions will be much appreciated! |
[2015-04-17 17:50:38] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#MoveBreakevenForStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-17 18:27:54] |
Hi, I tried it and it does not move the remaining order to Order entry-5. See attached screen shots - can you comment on what I may be doing wrong?
OrderQuestion2.pdf - Attached On 2015-04-17 18:27:30 UTC - Size: 168.02 KB - 478 views |
[2015-04-20 09:26:24] |
Refer to the attached screenshot with an example of how to configure the Targets tab. Notice the Move to Breakeven settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-21 17:18:59
Attached Order Example 2015-04-20.png / V - Attached On 2015-04-20 09:26:12 UTC - Size: 7.29 KB - 598 views |
[2015-05-21 14:20:04] |
jwick - Posts: 142 |
I'm having the same issue. My OCO Group Triggered based stop doesn't move. I viewed the both set of screenshots in this thread and don't see how the configuration between the two is different. I'm using IB, if that makes a difference. The stops used to work fine but suddenly stopped (haha) working the past two weeks or so.
[2015-05-21 19:26:17] |
We will be testing this today.
[2015-05-22 20:20:49] |
We have tested this and cannot duplicate the problem. Provide a screenshot of the Targets tab of the Trade Window with the Stop order selected. It can be attached following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-22 20:41:17] |
We determined the problem. It has to do with when using Interactive Brokers server-side bracket orders. This will be solved in the next release. Corrected a problem from a recent release where Trailing Stop orders including Move to Breakeven Stops were not functioning when using server side bracket orders with Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
