Date/Time: Mon, 13 May 2024 10:33:05 +0000
Force reload of data and restart study
View Count: 1013
[2015-04-16 22:45:13] |
Bitcoinadvisor - Posts: 14 |
Hello, We have a study that we would like to programmatically force an update and refresh of the study. To do this manually we have selected chart and chart settings from the menu and then clicked apply. Is there a way to perform this task within a study using code? thanks Andrew |
[2015-04-17 18:20:51] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scFlagFullRecalculate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
