Date/Time: Fri, 03 May 2024 23:00:25 +0000
data feed connection
View Count: 1429
[2013-05-31 23:04:20] |
You can change the service through Global Settings >> Data/Trade Service Settings. The set up instructions for each of the supported services can be found here: https://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
