Date/Time: Sun, 05 May 2024 20:04:06 +0000
[User Discussion] - Developing Midpoint
View Count: 2100
[2013-05-31 21:33:44] |
omni72 - Posts: 17 |
Hi SC Support - I am using the following 2 studies: Daily OHLC Study Subgraphs Average to create a Midpoint study, but have so far been unable to get the midpoint to stay drawn as it develops (MidpointDeveloping.jpg). In other words, rather than display like a VWAP line or Developing VPOC, it will just show as a straight line once charts are reloaded (Midpoint.jpg). What is the best way to retain the dynamically created Midpoint? Thanks and take care - Omni72 Date Time Of Last Edit: 2013-05-31 21:34:12
MidpointDeveloping.jpg / V - Attached On 2013-05-31 21:33:10 UTC - Size: 314.74 KB - 519 views Midpoint.jpg / V - Attached On 2013-05-31 21:33:20 UTC - Size: 828.96 KB - 469 views |
[2013-05-31 22:43:15] |
Sawtooth - Posts: 3993 |
In the Daily OHLC study, set the 'Graph High and Low Historically' to Yes.
[2013-06-01 01:32:55] |
Bravo! :) Thanks so much for the tip, tomgilb - unsurprisingly that did exactly what I was looking for :D |
[2014-04-16 02:32:58] |
User32803 - Posts: 18 |
What are the individual inputs for each of the studies to create and retain the dynamically created Midpoint? Any help would be appreciated.
[2014-04-16 17:57:08] |
Zosimus - Posts: 345 |
@User32803, here are the settings that work for me. You can change the "Use Day Session Only" and "Display on Day session Only". http://screencast.com/t/lsRkX2Root PS. @tomglib thanks for the idea :-) Date Time Of Last Edit: 2014-04-16 17:59:05
