Date/Time: Sat, 11 May 2024 19:52:23 +0000
What Happened to POC, VAH, VAL Lines Draw Types in Volume By Price?
View Count: 1085
[2015-04-09 15:22:54] |
cmet - Posts: 538 |
Updated to latest version (1246) and all of my POC, VAH, VAL Lines which were using the Fill Rect Top/Bottom draw type can only use Lines. Any attempt to change the draw type snaps them back to Lines. Doesn't work in 1245 either. Works fine in 1243. ?? Date Time Of Last Edit: 2015-04-09 15:29:05
[2015-04-09 16:56:48] |
This is not supported at this time in the newer versions. We will look into it in the next two weeks.
[2015-04-09 17:01:12] |
cmet - Posts: 538 |
Wow. Seriously? This is key for me. If this is a problem in VbP, can you at least consider putting this draw type along with duration in Bars into the Volume Value Area Lines indicator? Date Time Of Last Edit: 2015-04-09 17:01:45
[2015-04-09 21:57:24] |
i960 - Posts: 360 |
Yeah, it's also impossible to turn off value area high and low's display type - which I'm not sure if that in itself was a bug before, or what. I do know that something was potentially broken here in fixing the issue that joshtrader reported in regards to these lines. SC, if you break an existing functionality - it's a regression (even if you didn't know people were using/depending on something) which should be a fairly high priority to resolve. |
[2015-04-17 23:52:36] |
cmet - Posts: 538 |
Any update on this? Again, if you are going to remove the draw types from Volume By Price, can you please add "Bar" to the Time Period Type in the Volume Value Area Lines Indicator so the most recent version of the software can be used? |
[2015-04-18 02:03:31] |
Yes this was solved about a week ago. Update to the latest prerelease. Development has ceased on Volume Value Area Lines study. And also your request is very difficult and complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-18 02:14:19] |
cmet - Posts: 538 |
Thanks (would have been nice to know that it was solved by an update to the ticket).
