Date/Time: Wed, 11 Feb 2026 15:44:26 +0000
Millisecond - how to extract
View Count: 1207
| [2015-04-08 14:02:29] |
| like2trade - Posts: 117 |
Using GetSecond()and GetMinute() in ACSIL one can get the seconds and minutes for a bar. Is there any way to extract the milliseconds data for a bar? Thanks. |
| [2015-04-08 17:18:47] |
It depends upon the chart bars. If they are based upon a fixed amount of time they will not have milliseconds. Otherwise, refer to: http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#AccessingMilliseconds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
