Date/Time: Sat, 21 Sep 2024 01:02:27 +0000
Markers and custom text using spreadsheets ?
View Count: 2400
[2013-03-26 16:36:31] |
wwwingman - Posts: 185 |
Hi, Is it possible to use Excel/Spreadsheats to put markers and custom text on the charts ? I am not using formulas, simply static events I find important on historical charts, for my trading journal. Thank you, W. Date Time Of Last Edit: 2013-03-26 16:37:33
[2013-03-27 00:26:45] |
Sort of. The Spreadsheet studies let you draw Subgraphs on the chart and those have various Draw Styles including a Text style. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
