Date/Time: Mon, 13 May 2024 05:41:13 +0000
Font changed
View Count: 941
[2015-04-04 15:58:25] |
Ronin - Posts: 35 |
Hello, In on of ur recent version updates the font / font size has changed to a larger one I've tried to seek for the previous one and changed the size to smaller but couldn't get the default one u had after the change made How do I restore it? thanks |
[2015-04-06 03:52:09] |
Definitively through Global Settings >> Graphics Settings >> Fonts, you have the capability to set any type of font you want for the areas of the program where the font is controllable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-06 14:44:52] |
Ronin - Posts: 35 |
thanks, as I mentioned searched for the previous one (entire font list) but couldn't get the previous one u had before the change - what font setting (tabs) u had few versions before so I could restore it Date Time Of Last Edit: 2015-04-06 14:53:08
fonts ex.PNG / V - Attached On 2015-04-06 14:44:39 UTC - Size: 1.51 KB - 306 views |
[2015-04-06 17:42:22] |
We do now recognize the problem. The font selector was not displaying all available fonts, we thought it was. This will be fixed in the next release.
[2015-04-17 19:49:49] |
Ronin - Posts: 35 |
Hi, was it updated on 1247?
[2015-04-17 21:20:04] |
Yes.
