Date/Time: Sun, 05 May 2024 22:57:17 +0000
depth of market during a replay
View Count: 2221
[2015-04-03 12:17:25] |
User149687 - Posts: 2 |
Hello, why is not supported depth of market during a replay? Waiting orders could be usefull thing for papetrading. thank you. |
[2015-05-16 21:18:37] |
still waiting
[2015-05-16 23:04:28] |
This is not supported.
[2015-06-07 18:21:02] |
User889191 - Posts: 61 |
Hello I completely agree with User149687. In NinjaTrader it works. Why is it not possible.
[2015-06-07 19:50:19] |
Then please use ninja trader. Depth of market data takes too much space to store. It will not be supported.
[2015-06-08 11:12:07] |
O.k. But space is nowadays not an issue anymore. Disk space is very cheap. The user should have the possibility to replay with DOM data or without.
[2016-04-30 17:50:40] |
User305145 - Posts: 38 |
Is this still the case? I wish to replay the DOM with full depth |
[2016-04-30 18:12:50] |
Yes this is still the case.
[2016-05-07 05:44:59] |
User742717 Mike - Posts: 86 |
<IMO> This is an important feature for anyone using (finding new strategies etc) or wanting to learn the DOM. It's not just NT, its a real disadvantage for SC as it's common on most packages with a decent DOM. You have documented "replaying the trade DOM", but without the market depth, I don't understand how it can be useful. http://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#ReplayingTradeDOM Perhaps, it could be implemented as a recording option (with an expiration) like: http://www.sierrachart.com/index.php?page=doc/doc_RecordingModes.php#DataRecordingSuffixes I'm sure this would be a big feature to consider, so maybe research or survey users/partners etc. Personally, I like capturing as much data, so when something of interest happens, I can just replay it 100%. As SC can't do this, I record my screens mostly for this purpose. </IMO> |
[2016-05-07 06:53:18] |
Refer to the latest post in this thread here: Notice: Suggestions (Currently not accepting) So this capability is coming. No further comment at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
