Date/Time: Thu, 02 May 2024 05:12:43 +0000
going back
View Count: 1958
[2013-03-26 16:35:55] |
Frontrunner - Posts: 20 |
hi support, is there a way to go back in time to a particular day several years ago to pull up a chart? For example in the emini market? Thank you |
[2013-03-26 17:05:26] |
You will need to use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html Please refer to help topic 42 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
