Date/Time: Fri, 26 Apr 2024 20:47:04 +0000
Version 982 NoCLR installer issue
View Count: 1524
[2013-05-30 18:37:49] |
ganz - Posts: 1048 |
Hello. v982 NoCLR installer file has wrong size. Please, check it. Thank you. Date Time Of Last Edit: 2013-05-30 18:40:29
[2013-05-30 18:46:19] |
Yes, you are right. We are uploading a new version now.
