Date/Time: Sat, 18 May 2024 07:24:51 +0000
int TickBars = sc.AreTickBars(); won't build
View Count: 860
[2015-03-28 04:23:51] |
maxpi - Posts: 175 |
int TickBars = sc.AreTickBars(); if I insert this into code it will kick out an error when I build it.
[2015-03-28 17:33:16] |
Marmany - Posts: 303 |
sc.AreNumberOfTradesBars() works OK in SC v1241
[2015-03-28 21:02:37] |
The name has changed and is given in post #2.
[2015-06-16 19:36:09] |
DarthSidious - Posts: 63 |
Can you update the documentation at http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scAreTickBars please?
[2015-06-17 05:14:46] |
Thank you for pointing this out. We are going to correct this now.
