Date/Time: Mon, 20 May 2024 02:14:04 +0000
How to adjust Cross-hair line width or visibility
View Count: 3508
[2015-03-25 03:11:52] |
Willson - Posts: 176 |
My cross crosshair becomes nearly invisible if I have price or time lines on chart. Even if I choose way different colors. I notice that TradeStation offsets the crosshair a tiny amount from the price lines which makes it visible and it seems much thicker also. Is there a way to make crosshairs visually stand-out from price grid lines? Regards |
[2015-03-25 18:04:58] |
It is not possible to change the thickness. All of the attributes that can be changed are in Global Settings >> Tool Settings >> Chart Values.
[2015-03-25 18:32:41] |
Regards Please add this capability to a hope list. It is very important to those with impaired eyesight as well as those who are trying to train others using video. |
[2015-06-09 15:25:02] |
doctor10 - Posts: 78 |
Would ask for support to change the cross crosshair thickness/width as well tnx
[2015-06-12 05:14:51] |
We will see about this.
[2015-06-12 22:27:55] |
Al SC Developer - Posts: 434 |
In the next version you can set the width of the chart values tool via Global Settings >> Tool Settings >> Chart Values
[2018-07-25 12:06:20] |
DogBone01 - Posts: 14 |
Please add the ability to decrease the thickness of the Chart Values/Crosshair.
[2018-07-26 16:55:15] |
This is controlled through the Graphics Settings: Graphics Settings Chart Values: Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-27 01:03:50] |
Thank you. I didn't scroll down far enough in the settings menu to find it. Forgive me for wasting your time. Todd |
