Date/Time: Sun, 19 May 2024 10:21:28 +0000
IQ Feed ports
View Count: 790
[2015-03-20 04:52:44] |
User20683 - Posts: 12 |
Currently it looks like if the IQ Feed registry settings are missing SC will not connect to IQ Feed because it can not look up the port number. Can you please attempt to connect on the default ports in case those registry settings are missing? IQ_Level_1_PORT = 5009 IQ_LOOKUP_PORT = 9100 IQ_Level_2_PORT = 9200; IQ_ADMIN_PORT = 9300; IQ_DERIVATIVE_PORT = 9400 Thanks |
[2015-03-20 07:06:50] |
Yes we can do this. It will be out in the next release.
