Date/Time: Fri, 26 Apr 2024 17:25:19 +0000
Chart auto scrolling
View Count: 2153
[2013-05-29 15:01:13] |
fxz - Posts: 32 |
Hi would be doable to insert a button or a menu function to re establish the chart auto scrolling automatically? Using the mouse on the left-right bottom scroll menu is ok for timeframe till 1sec but when in CS ticks is selected there are more ticks added at any time than the speed of the window to reallign for autoscrolling (to get the bottom right little square become again green is very difficult when CS is ticks) Thanks Date Time Of Last Edit: 2013-05-29 17:17:07
[2013-05-29 20:17:54] |
As long as you are at the end of the chart, as new bars are added, the chart will always scroll to the very end. To go to the end you can press the END key on your keyboard or select Chart >>Go to End of Chart. You can add a ToolBar button for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-29 20:19:18
