Date/Time: Sun, 19 May 2024 08:35:54 +0000
Drawing presets and various toolbar issues
View Count: 789
[2015-03-18 15:58:41] |
User17836 - Posts: 12 |
A sporadic issue 1) When using a drawing tool - say the rectangle - the preset buttons are grayed out and not clickable. Cannot pinpoint what the start of the problem is.. Eventually this sorts itself out and the buttons start to work again. -side issue: the buttons for presets 3,4,5 do not have an icon at all. 2) Tool bar can seem to have several tools selected at once... I am on the "optimums" version for what it's worth. |
multiple selection.png / V - Attached On 2015-03-18 15:57:06 UTC - Size: 7.71 KB - 282 views drawing presets.png / V - Attached On 2015-03-18 15:57:10 UTC - Size: 9.03 KB - 281 views |
[2015-03-18 20:03:32] |
1. This will be solved when the new ToolBar/Control bar is released. 2. We have never heard of this before. We would expect it to be solved with the new control bar. 3. -side issue: the buttons for presets 3,4,5 do not have an icon at all. The icon will be different but it should be there when the button is enabled.
[2015-03-19 12:53:10] |
ganz - Posts: 1048 |
SC Support == deleted == Date Time Of Last Edit: 2015-03-19 19:46:36
[2015-03-19 19:51:05] |
SC Support pls., disregard my post #3. the issue was on the crossover's side. sorry. and i've stopped to report any issue using Linux/wine in order not to waste your time. thnx. |
