Date/Time: Sun, 19 May 2024 04:55:31 +0000
Crude Oil rollover?
View Count: 1095
[2015-03-18 15:14:06] |
User38993 - Posts: 61 |
Hello I set chart to rollover automatically, but it seems to be that it didn't rollover. I used Date rule roll over, but it didn't roll over today to Crude oil May. What am I doing wrong? for date rule roll over, doesn't it roll over 2 days before expiration date? |
[2015-03-18 19:46:04] |
How did you set the chart to automatically rollover?
[2015-03-18 20:02:53] |
Under chart settings, i checked automatically rollover
[2015-03-18 20:20:26] |
Check the rollover rules for the symbol in Global Settings >> Symbol Settings to know when the rollover will occur.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-03-18 20:20:39
