Date/Time: Wed, 23 Sep 2026 05:03:47 +0000
Vol Profile problem
View Count: 1112
| [2015-03-17 18:30:32] |
| pismo10 - Posts: 171 |
Using 1239, ES 1.25 range chart. When i draw a vol profile across a few bars it prints the profile and then when the next tick occurs if often moves the profile back one bar. The thin rectangle that shows what bars the profile is drawn on stays correct but the profile moves one bar. Just started with upgrade to 1239. I Use profile all the time. Thanks |
| [2015-03-17 21:40:26] |
We are releasing version 1241 now which may solve this problem.
