Date/Time: Sun, 19 May 2024 08:47:41 +0000
chart scaling
View Count: 1132
[2015-03-17 17:49:35] |
User229008 - Posts: 1 |
Hello! I cant scroll on a renko chart. My goal ist to set a line or a fixed period where the chart starts drawing, market delta is able to do so. Because it really sucks when the chart draws into the long term profile on the right side. On renko.jpg you see the renko chart goes into the compsite profile. On renkodelta.jpg you can see how market delta solves that problem with a dynamic line what is able to change where the candlechart starts drawing. Regards |
renkodelta.JPG / V - Attached On 2015-03-17 17:47:03 UTC - Size: 62.37 KB - 299 views |
[2015-03-17 20:54:37] |
You can solve this by adding fill space and locking it: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
