Date/Time: Sun, 19 May 2024 08:36:04 +0000
US Stocks/Equity data feed
View Count: 887
[2015-03-16 21:29:17] |
bwalks123 - Posts: 122 |
I am looking at setting up some stock charts utilizing the Volume By Price study, what SC data feed would I need to buy? I have a live TD Ameritrade acct but not sure if their data with be accurate for the Volume By Price study. Thanks |
[2015-03-17 04:33:48] |
For the greatest accuracy you would need the Sierra Chart Exchange Data Feed which is documented here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-03-17 14:46:13] |
Ok, now what is the difference between BATS only feed for $2.50 and the US equities feed for $10.50?
[2015-03-17 17:17:10] |
The only thing that we can say about the difference is that the data comes from a different exchange. Also refer to this section here: Sierra Chart Exchange Data Feed: Stock Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
