Date/Time: Sun, 19 May 2024 05:07:06 +0000
Multiple connenction to SC on three PC
View Count: 775
[2015-03-16 17:28:24] |
brobrobro - Posts: 2 |
Hi, I have one question. I need to run SC on three computers at once time, but that I could subscribe to one account. It's only for backtesting. What are my options ?? Thank you for your answer. Regards. |
[2015-03-16 17:35:28] |
Sierra Chart - Max - Posts: 5618 |
To use Sierra Chart on 3 computer simultaneously you will need Sierra Chart package 5. To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package". The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted. Sierra Chart Support |
[2015-03-16 18:04:26] |
I thought so, but I was not sure. Thank you for the quick response. Just for information, what other benefits does a package 5?? I read something on your site, but you know more. Regards |
[2015-03-16 18:11:16] |
Please refer to the Package Table here: https://www.sierrachart.com/index.php?page=doc/Packages.php#Table Sierra Chart Support Date Time Of Last Edit: 2015-03-16 18:11:33
